Re: H charging problems....again
Posted by Janicholson on September 28, 2010 at 19:36:33 from (67.72.98.45):
In Reply to: H charging problems....again posted by Fullers Farmall on September 28, 2010 at 19:29:52:
If it is operating correctly it will charge only enough to keep the battery fully charged. If when it is started it charges for 15 to 30 minutes, then goes back to near no charge, it is just fine. Battery voltage is the key to this. If it is at 3/4 throttle the battery volts should be a 7.1 to 7.3 (use a needle style meter, or a very good digital) mediocre digital meters will bounce all over the scale. If it is not charging, the voltage will be about 6.3 volts (or less) Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
