Re: Magneto/distributor drive... oil seal?
Posted by Theman on September 29, 2010 at 10:19:02 from (65.198.133.254):
In Reply to: Re: Magneto/distributor drive... oil seal? posted by chevy_cowboy on September 29, 2010 at 08:42:40:
Disassembly is easy. The gear is driven by a woodruff (half-moon) key and is a close fit on the shaft - but not difficult to remove. Just be sure to mark the distributor drive slot position BEFORE pulling the drive away from the front cover. I recommend setting the crankshaft to TDC just so you know you're close before you try to start the engine after putting everything back on.
