Re: Flush out a Farmall 706 Engine
Posted by relaurain on September 29, 2010 at 14:20:06 from (97.73.64.169):
In Reply to: Flush out a Farmall 706 Engine posted by IndianaScott on September 29, 2010 at 07:41:27:
This might raise some eyebrows but you can use Kerosene. It has enough lubricating properties to keep the motor safe and it cleans sludge out really good. Drain all old oil out and fill it up. Just watch the temp and don't get it too hot. Drain it out after a while and refill with normal oil.
Works good and cheap. Then you can use it for the burn pile!
