Re: Farmall M vs. McCormick Deering W-6
Posted by Wardner on September 29, 2010 at 17:14:49 from (4.154.238.63):
In Reply to: Farmall M vs. McCormick Deering W-6 posted by shaun thurman on September 29, 2010 at 07:54:46:
In the later models such as the W-400 and corresponding F-400, the PTO shafts and the radiator caps are at the same respective heights.
Not sure why a W-6 and a M differ so greatly but it has to be the tires and the knuckles on the wide front M.
You can add alot of stability by half filling the rear tires with liquid ballast.
To follow up on Jim's suggestion regarding springs, the 650 and some predecessors used three transverse leaf springs in the front axle trunion. On the other hand, my W-400 does not have them and there is no room to install them. It would require a deeper trunion.
