Re: Cranking up my '39 A.
Posted by Dave_Id on September 29, 2010 at 17:28:28 from (50.8.4.26):
In Reply to: Cranking up my '39 A. posted by Enar on September 29, 2010 at 17:04:04:
With that much cranking, their should be gasoline all over the floor. I would guess you aren't getting enough gas. Pull a couple of plugs to see if they are wet. And check for spark on those same plugs as you crank it. Ask your wife or some other unsuspecting person to hold the spark plug and then crank it over. If they get a good shock, then you have spark... I had a long day today.
