Re: Cranking up my '39 A.
Posted by Enar on September 29, 2010 at 19:11:53 from (98.244.241.123):
In Reply to: Cranking up my '39 A. posted by Enar on September 29, 2010 at 17:04:04:
Thanks for the info, guys. I didn't touch the magneto when doing the work so it should be in time. I'll pull out a couple plugs tomorrow to see if they're wet. We used to do that with our cars back in the 50's and before. It was easy with flatheads! I will shoot a little oil into the cylinders also. I did rebuild the carburetor, but I think I got it done right and reset as the instructions said. Thanks again.
