Posted by Tom Fleming on September 30, 2010 at 02:29:13 from (206.193.253.243):
In Reply to: Headache posted by Tyler Jackson on September 29, 2010 at 16:21:20:
Heat, penetrating oil, then heat again, then penetrating oil, then apply the puller. One little trick to use, is to use a hammer, and give the center bolt a sharp rap after you have torqued the bolt down a good bit. This will shock the assembly and will usually pop the piece that you are removing. Use this technique on steering wheels, fly wheels, etc.
Now, don't beat on the pulling bolt, just 1-2 sharp hits will usually do it. if the first attempt doesn't, then turn the bolt another 1/2 turn or so, and hit it again. Don't be bashful, but on the other hand, don't use a 10lb sledge either.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
