Re: farmall h with higher compression
Posted by Andrew Z on September 30, 2010 at 05:01:09 from (64.252.124.201):
In Reply to: farmall h with higher compression posted by pintobill on September 29, 2010 at 21:07:06:
Pretty much as John says the main difference is the head, larger combustion chamber, valves are slightly different as well. Externally the manifold and jetting in the carb are different as well.
Andrew
