Re: HELP! IH 184 Lo-Boy - Engine Bogs Down When Mower is ...
Posted by James Williams on September 30, 2010 at 06:08:44 from (74.47.205.155):
In Reply to: HELP! IH 184 Lo-Boy - Engine Bogs Down When Mower is Engaged posted by RTR on September 29, 2010 at 21:58:20:
Your tractor is probally running fine,These little tractors are gutless.They do a good job if you mow your grass every week or LESS
jimmy
