First do a little inspection. Start at the steering post. Make sure both collars are up against the post and set screws are all in there. Go down to the u-joint. Replace cross if it is wobbly. Continue down to worm gear and sector. Make sure that top nut is TIGHT! Make sure the front cap nut is tight. Check the center and forward shaft bushings. If you eliminate all the play in the shaft portion you are more than half way home.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
