Re: 706 Gas, engine dies
Posted by bc on September 30, 2010 at 11:31:24 from (69.151.186.34):
In Reply to: 706 Gas, engine dies posted by Brett Ulrici on September 29, 2010 at 19:11:30:
You need full fuel flow for a few minutes. Get a hose and drain the gas into a gas can for a while. Sound like you have the standard rusty gas tank problem. It dies so fast when it runs out of gas that you think it is an electrical/ignition problem. Once the carb refills with gas, then it starts and runs till the line plugs off again. Sometimes you can get just enough flow it will run for 5, 10, 15, or 20 minutes. Crank up the throttle when you do this.
