Re: Second day of cranking the A
Posted by ScottyHOMEy on September 30, 2010 at 19:55:20 from (71.241.193.87):
In Reply to: Re: Second day of cranking the A posted by Enar on September 30, 2010 at 19:43:13:
Another idea, related to fuel. Where you've had the carb off and been painting, too. Check out the gasket between the carb and manifold, and that they are torqued god'n'snug together. Same with manifold-to-head if you had that apart.
An air leak in any of those joints could make for the problem you're having. An easy test (Okay, not so easy if you're cranking by hand, but . . . call it part of the charm of the old darling) once yu're sure the ignition is squared away, is to crank while spraying a combustible around the joints mentioned. If it fires to run it means it is taking on fuel from a leak in that intake joint, which robs your carb of the vacuum it needs to do its job.
