Re: No spark past coil on H
Posted by Phil Auten (TX) on June 19, 2000 at 07:41:08 from (206.175.72.226):
In Reply to: No spark past coil on H posted by Rob Scott on June 18, 2000 at 21:07:06:
Rob,
Was it running before the cap and rotor were replaced? If it was, reinstall the old parts one at a time, being sure you get the wires on in the proper order. If this fixes it, you know you got a bad part. It does happen. Return it for a replacement and try again.
If it was not running before, check the wiring to the mag switch to be sure it isn't shorted to ground somewhere, check the point gap and clean them and be sure the impulse is tripping. If all is well there, check the condenser by removing it. If it fires then, replace the condenser. Just be methodical by checking one thing at a time and you can get it figured out.
Good luck,
Phil
Post A Followup
: Re: Re: No spark past coil on H
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
