Re: Farmall Super A
Posted by Janicholson on October 01, 2010 at 08:01:18 from (199.17.6.223):
In Reply to: Farmall Super A posted by Philip Rosenberg on October 01, 2010 at 05:09:01:
Zero compression in all cylinders is dramatic.
Does the gauge work!?
Are the valves adjusted correctly while in the correct cam rotation.
Are there rags left in the intake track?
Are the gaskets put on wrong?
Are the rockers moving at all when the engine turns?
let us know these answers please. Jim
