removing a belly pump on a M
Posted by Don in MN on October 01, 2010 at 09:27:50 from (64.61.211.19):
I came up with a easy, and safe way to remove the belly pump on my M alone. After removing the pluming, drive coupling, I placed my floor jack, and blocking up tight to the bottom of the pump. I then removed the four bolt's and then lowerd the pump about an inch and a half. I cut four piece's of 3/8 threaded 18 inches long, put the rod's up through the bolt hole's in the pump, and put a nut on top and bottom side of the pump, and then turned the rod's tight up into the existing bolt hole's. Turning the bottom nut down a couple of inches at a time, and slowly lowering the jack, then run the top nut down to act as a jam nut to keep the pump from twisting. Had the pump out in less than a half hour. Reverse the procedure for putting back in.
