Re: International 444 PTO problems?
Posted by Jimb2 on October 01, 2010 at 09:31:42 from (99.240.236.11):
In Reply to: International 444 PTO problems? posted by Michaelih444 on September 30, 2010 at 21:30:43:
Hi Michael, check the PTO engagement lever, I have seen them bent so that the PTO collar mechanism does not completely engage. This happens for two reasons, first the dual stage clutch is out of adjustment and is not completely releasing the PTO drive, second, Operator does not realize tractor has dual stage clutch, 1/2 down stops transmission and all the way to floor board stops PTO and transmission. The Operator will attempt to force the PTO into gear without pushing clutch to the floor.
If the pin is sheared the PTO is usually engaged or disengaged and PTO lever has no effect. But pin could also be bent.
The PTO engagement lever and control rod with pin can be removed by removing the 3 studs around where the control rod goes into transmission case.
You may want to park tractor on a slope with the PTO lever on the high side so transmission oil does not leak while removing PTO lever and control rod.
JimB
