Re: Backlash, again
Posted by CNKS on October 01, 2010 at 09:57:44 from (216.144.104.128):
In Reply to: Backlash, again posted by Hendrik on October 01, 2010 at 07:46:25:
I'm replacing the bearings as you did. In my previous response I said I thought I had it fixed, now it seems too loose. I have a 0.004" shim ordered from CaseIH, may not get here until Wed. If you don't mind, you can send me a picture at cnorwood@wbsnet.org. Not sure I understand how you got calipers in to measure the backlash. The only way I see to get anything in is to remove the 4 differential gears, then it's a long reach. I did remove the thinnest shim from the front of the countershaft. It seemed to make it too tight, so I put it back. But, I'm not sure of that either, as for whatever reason, I did not get the front bearing seated right. Had problems after I put the shim back in. I drove it in with a hammer and socket on the inner race, I did not do that with one shim removed, that might be why it was too tight. And, the book says the ring and pinion are supposed to be flush at the big end of the pinion (front end). I cannot see that as the housing is in the way. The small end appears flush. So, I'm still messing with it. This is the one thing I have to get right.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
