Re: Farmall Super A
Posted by tractorsam on October 02, 2010 at 04:04:37 from (24.222.151.48):
In Reply to: Farmall Super A posted by Philip Rosenberg on October 01, 2010 at 05:09:01:
Before you go any further I would start looking at the basics. If you
have 0psi compression then there is something really wrong, even
very leaky rings will make 'some' compression. The only times I've
seen zero compression were valves stuck open. For what a few
tablespoons of oil cost it's well worth doing a wet compression
test. Something else you can try - remove all the rocker arms,
remove the spark plugs, take a blow nozzle on your air compressor
and blow air in each spark plug hole (you may need to wrap a rag
around it to get a seal) then all you have to do is see where the air
leaks out and that's your problem spot. Sam
