Re: Farmall M Brake Adjusters
Posted by rustyfarmall on October 02, 2010 at 06:19:17 from (209.152.78.140):
In Reply to: Farmall M Brake Adjusters posted by Melvin Ware on October 01, 2010 at 18:56:30:
Yes, and if that spring and clevis assembly is removed from the tractor, nothing else will get damaged. I took them off and held them in the vice on my bench. Much easier to work on that way.
