Re: Farmall Super A
Posted by El Toro on October 02, 2010 at 07:24:09 from (108.3.200.96):
In Reply to: Farmall Super A posted by Philip Rosenberg on October 01, 2010 at 05:09:01:
Before you pull a piston check the rotor and valves to see if they're all moving when cranking the engine. You may have a broken cam or camgear. Hal
