Re: Farmall Super A
Posted by Owen Aaland on October 02, 2010 at 13:31:33 from (65.174.247.47):
In Reply to: Farmall Super A posted by Philip Rosenberg on October 01, 2010 at 05:09:01:
If you did not reset the valve clearance after reinstalling the head most likely the valves will not be closing completely.
The machine shop will have removed material from both the valve face and the seat in the head resulting in the valve stems extending higher above the head. If the valves are not reset the rocker arms will hold the valves open slightly which could result in no compression on any cylinder.
