Posted by El Toro on October 03, 2010 at 04:56:20 from (108.3.200.96):
In Reply to: Farmall Super A posted by Philip Rosenberg on October 01, 2010 at 05:09:01:
It may be difficult to find your No1 piston at TDC on the compression stroke since you don't have any compression. Drop a long plastic straw on top of No1 piston and have someone hand crank the engine while you watch the straw rise. When it quits rising check to see if your timing mark is aligned. If it isn't aligned rotate it one more full turn and see if it's aligned now. Set the clearance at .017" cold.
When the engine is at TDC on No1 piston you can adjust valves 1,2,3 & 5 counting from the radiator, then rotate the engine one full turn and adjust valves 4,6,7 & 8. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
