If it is running you can assume the ignition is working. If it has a magneto ignition it is a self powered system that has no battery power hoked to it at all. It has a small internal generator inside the housing that with other parts makes timed spark to each plug. It is recognized by being an all in one unit. The Cap from which the spark plug wires originate has a center terminal connected by a short spark wire that goes to the rounded cover on the top of the unit. A distributor will have that wire going to a separate coil on a different bracket. (usually a cylinder of some description. A mag is connected to a kill switch that grounds the mag side terminal, shutting off spark. A point and coil distributor has power going to the separate coil from the ignition switch. On Farmalls the switch for both look the same from the button point of view, but one is a grounded switch with only one terminal, and the other gets power from the amp meter and has two terminals. The trouble shooting guide included will help. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
