Posted by MisterT on October 03, 2010 at 09:45:34 from (209.152.78.140):
In Reply to: 460 Utility Carb woes posted by AL Farmall Boy on October 03, 2010 at 06:06:29:
Where is the fuel going to? The only way gasoline can escape from the carb while the engine is off is by leaking out, and there is only 3 places where this can happen. One is through a crack in the fuel bowl (not likely) next would be the fuel bowl drain plug(visible) and the third suspect is the packing in the high speed idle adjustment screw, which is also visible. If the tractor runs just fine after you get it started, you do not need a complete rebuild kit.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
