Re: 350 bolster shaft length
Posted by D Slater on October 03, 2010 at 12:05:12 from (184.15.34.152):
In Reply to: 350 bolster shaft length posted by jcwag on October 03, 2010 at 07:16:08:
22- 1/8 inches from the shoulder where the lower bearing and spacer rests to the top of splines where the threads start. Most 350 didn't have a keyway. Biggest part of H used the same size shaft as a 350 but 2 different ones for earlier ones. Most bolsters shafts have up and down play, are you checking height with shaft up? Splines are tappered so if gear is moving on shaft its not tightened down enough most times.
If the shaft happends to be short or not the correct lower bearing or spacer installed, the sector gear would probably contact the bolster before it tightened on the splines. If I remember right one earlier H shaft didn't use a spacer but the bolster or bearing may have differed instead of shaft length. Can't remember for sure.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
