int 424 two stage clutch repair
Posted by INT 424 on October 04, 2010 at 17:49:52 from (208.20.53.19):
I have a 424 tractor with a 2 stage clutch. The clutch throw out levers are worn out but the bearing appears to be ok. Can the levers be replaced through the inspection hole on the bottom without splitting the tractor and pulling the entire clutch assembly out? Are the adjusting bolts long enough to releave the spring pressure without threading out. Also does anyone have and idea on what would cause the second stage clutch to be extremely hard to push. Don't know if it could be from the worn clutch levers.
