Posted by pete 23 on October 04, 2010 at 20:31:25 from (184.12.35.82):
In Reply to: To Pete 23 posted by Larry B 1486 on October 04, 2010 at 16:14:23:
Well, I would go for the easy stuff first. There is an o-ring under the primer pump bail, if I remember correctly you can put a small punch in hole plunger stem and screw off the knob to replace o-ring. Other wise, look very carefully for any sign of wetness at the pipes from primary pump to final fuel filter and at filter. Really, if you have a good head of fuel in tank, the pump head should not drain back but if pumping helped it is draining back. There are inlet and outlet check valves in the primary pump and seal on shaft but that would require removal of the primary pump. That can be done without removal of main pump but can get a little tricky with gov spring etc. Main plunger and head should not be contributing to problem. If you have an auxillery fuel tank below pump level that could be a source of the problem also.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
