Re: Re: Super C Starting Problems
Posted by Les Repair on June 19, 2000 at 18:07:23 from (206.28.174.191):
In Reply to: Re: Super C Starting Problems posted by Phil Auten (TX) on June 19, 2000 at 07:46:56:
When you say bench tested, did they just check for shorts. If the bushings are worn the armature will show signs of rubbing the fields. Does the starter have a center bushing? Should have one. You can also go to a 4 field starter such as used on a Super M.
Post A Followup
: Re: Re: Re: Super C Starting Problems
