1950 C front clamp-on rims
Posted by Dave BN on October 05, 2010 at 17:04:37 from (205.188.116.73):
Finally saved up enough money to buy new front tires and rims to replace the old ones on my C. Put the right one on-no problem. Left rim won"t go on the hub. Closer inspection reveals that the "notches" cut into the hub, that keep the wheel from spinning(?), are different. The notches are not as deep on the left side and the square plate welded onto the rim won"t allow the rim to go on. Was going to grind one notch deeper but noticed that the "good" side has extra cast metal on the inside of the rim at these points but the "bad" side doesn"t. Both hubs have cast code 6787-DC but the left (bad) side has a date code of 7*17*J. That makes it 1940 correct, which could not have come on my 1950 C. The right side has no cast code. Do I have a hub from an A, H or M on the left? But, since they have the same cast code shouldn"t they be the same part? Help. Dave
