Re: pulling injectors
Posted by pete 23 on October 05, 2010 at 18:12:11 from (184.12.35.82):
In Reply to: pulling injectors posted by MikeO-WI on October 05, 2010 at 05:41:56:
You need to put in new brass sleeves and will have to borrow or fashion a driver to install them. I usually take a cut off tool on a die grinder and split the old brass sleeve to rescue the injection nozzle. Far as getting the coolant out of the cyl, well that is the biggest problem I would say. Air nozzle in cyl, then dry it up with some thing like brake cleaner and then oil it down really good. I guess I have always been fortunate enough to remember to drain coolant before pulling the nozzles.
