Posted by James Rumph on October 06, 2010 at 02:18:52 from (96.27.101.101):
In Reply to: cutting an H head posted by pintobill on October 05, 2010 at 18:56:49:
It won't hurt to get it cut just to make sure it is flat !
I had a 8060 "M" head cut .125 and that was to much ,it caused cracks to start forming.
I have a 450 gas head that was cut .040 and that has worked fine.
Keep in mind that when you cut the head there is a point that you will have to put spacers under the rocker arm pedestals to bring the adjustment back into the rockers.
Do a search on this topic i'm sure this has been asked before.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
