Re: HELP! IH 184 Lo-Boy - Engine Bogs Down When Mower is ...
Posted by mkirsch on October 06, 2010 at 05:13:57 from (64.80.108.57):
In Reply to: HELP! IH 184 Lo-Boy - Engine Bogs Down When Mower is Engaged posted by RTR on September 29, 2010 at 21:58:20:
If you can't mow with the deck down, it doesn't have "plenty of power."
Have you tried any suggestions we've given you over the last week?
Looks like a nice straight tractor, but until you figure out the power problem you really only have a pig wearing lipstick :)
What do you mean the brakes don't work? Do the brake pedals hit the mower deck when it's up?
Help us out here a little! Most tractor "mysteries" can be solved by simply looking carefully. Follow the mechanism... You push on the brake pedal to activate the brakes, right? Well, get someone to sit on the seat and push the pedal while you crawl around down below looking for the problem.
