Re: Farmall H won't start
Posted by RB on June 19, 2000 at 18:44:33 from (63.28.169.193):
In Reply to: Farmall H won't start posted by Dave on June 19, 2000 at 18:33:35:
Make sure all of your connections are good and tight.If you have changed all of the starting componets,it should start.Only other thing I can think of is when you replaced the starter,did you clean the area where it mounts good?
Post A Followup
: Re: Re: Farmall H won't start
