Re: HELP! IH 184 Lo-Boy - Engine Bogs Down When Mower is ...
Posted by mkirsch on October 06, 2010 at 10:08:33 from (64.80.108.57):
In Reply to: HELP! IH 184 Lo-Boy - Engine Bogs Down When Mower is Engaged posted by RTR on September 29, 2010 at 21:58:20:
It's all cool.
Don't listen to the guys that say these tractors don't have the power to run a 5' mower. That's baloney.
That 184 is the most powerful version of the Cub ever built. Running properly, it should have more than enough power to run the mower.
I've personally had two much older Cubs, a 1966 and a 1967, both with 5' mower decks on them. That 1967 would take a full cut in heavy grass with no problems. The 1966 wasn't so good at first but after sharpening the blades, tilting the deck properly, and doing a complete engine tuneup, it would take a full cut in heavy grass too.
