Re: cutting an H head
Posted by pete 23 on October 06, 2010 at 10:40:57 from (184.12.35.82):
In Reply to: cutting an H head posted by pintobill on October 05, 2010 at 18:56:49:
I'm with the idea, only remove enough to clean it up, the way those water passages are formed you get to making them wider with every little bit you take off and then weaken the head. I have(years ago) installed high altitude fire crater pistons. That really brings up the comp ratio. Don't know if they are still available . Also, you will need to adjust your timing advance curve with any fire crater piston.
