Re: HELP! IH 184 Lo-Boy - Engine Bogs Down When Mower is Eng
Posted by Shawn in PA on October 06, 2010 at 10:43:40 from (24.154.38.87):
In Reply to: HELP! IH 184 Lo-Boy - Engine Bogs Down When Mower is Engaged posted by RTR on September 29, 2010 at 21:58:20:
Looks like everything is already covered. The only thing I can add is pretty obvious, but...You wouldn't happen to have taken the blades off between taking it to the dealer and having these problems? You'd probably notice a poor cut, but are the blades on backwards? Just a thought. Do you have any other way of putting a load on the tractor other than the mower deck? Maybe like a plow? That might help narrow it down to a deck vs motor issue...Shawn
