Just clean the bore top and bottom good. IH used to say to use loctite but I guess most don't bother with it, I do. What I do is put a dowel or rod in the end of a drill, cut a slot in it and put some emery cloth in slot. After some expermenting it does a good job. Make sure the hole into cyl in both the holes where sleeves came out and the other ones is cleaned of carbon also. A long drill bit correct size works, I always used a reamer ( with a safety clamp on it so I didn't drop it into cyl). When putting in the nozzles , leave off seal and gasket and try it in sleeve, should just drop right into bottom or you may end up with a combustion leak.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
