it is very likly a standard liftall cylinder it is described as being about a foot long at the cylinder with 3 or 4 tie bolts holding the ends on. It has a sleeve sticking out one end with the push rod inside it, and a mount hole on the hydraulic connection end. They should be easily repaired with leather cups and seals from several sources, including NAPA and hydraulic shops. caseIH is also likely to ghave the parts. They are also very easy to find used. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
