Re: Starter options for 544D Hydro
Posted by Jimb2 on October 09, 2010 at 06:41:20 from (99.240.236.11):
In Reply to: Starter options for 544D Hydro posted by Dave from MN on October 09, 2010 at 06:07:27:
Hi Dave, I assume it is a German D-239 Diesel engine. Does it have the proper starter for the Hydro model?
From caseih parts:
1113198 MOTOR ASSY, cranking, 396574R91, 12 volt, gear drive tractors
1113201 MOTOR ASSY, cranking, 400121R92, 12 volt, hydrostatic drive tractors
The D-239 is harder starting than some of the other German Diesels. The D-179 and D-206 are the best starters.
I don't know if this works or not but a mechanic that I know that works at a large construction firm, said that they had stopped using ether several years ago and now use WD40 instead as a starting agent. He said the can of WD40 must be warm not left out in the cold.
JimB
