Re: Lead additives
Posted by Leon Torkelson on October 09, 2010 at 08:25:24 from (74.36.51.1):
In Reply to: Lead additives posted by g hanson on October 09, 2010 at 07:41:07:
I make no claims to be knolageable about engines. However I have been on the farm all of my life so you learn some stuff. Lead was not put in gas untill the mid to latter thirties when higher compression engines were being put in cars. I have Ford model T and model A cars and trucks, all low compression about 5:1. Most older 4 cylinder tractors are not much over that. I run unleaded gas in all of my tractors and old cars. If I am going to do heavy work with a tractor, like plowing, I put in a little lead additive. I ve had the same bottle for about 10 years. I live in Minnesota so we have 10% alcohol in the gas and they are talking about going to 15%.
