Re: Weight of MD flywheel
Posted by D Slater on October 09, 2010 at 09:48:15 from (184.15.39.25):
In Reply to: Weight of MD flywheel posted by BruceS. on October 09, 2010 at 04:14:46:
95 pounds approximate. After the bolts are removed the flywheel needs to slide back a little because of 2 dowel pins. Sometimes they will slide off easy and sometimes they are stuck.
Makes it simpler for me if I use 2 longer 1/2 inch fine thread bolts with the heads cut off to remove and install. Screw them in the crank, then after flywheel is free slide it off and down.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
