super c rear axle leak and front engine seal leak
Posted by S Muse on October 09, 2010 at 17:47:12 from (65.191.13.199):
just bought a "52 super c couple of months ago. I knew the front engine seal was leaking i"ve used it a good deal around the house and at me parents disking and bush hoggin. bearly dropped any oil. now the rear wheel/axle just started leaking and the side/belt output shaft on the PTO stated leaking. I do not intend to use the belt shaft so i was wondering if it could be easily removed and sealed off or how hard it is to replace the other leaking seals
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
