Re: Farmall H won't start
Posted by Big M on June 20, 2000 at 08:39:13 from (198.133.22.71):
In Reply to: Farmall H won't start posted by Dave on June 19, 2000 at 18:33:35:
Sounds like a bad ground somewhere. I had
the same thing on my Super A. It just didn't
start. I tested everything, finally just before
I was about to buy a new switch, I put a tester
on it and found that there was a bad ground.
I then proceeded to take the switch apart and
then cleaned the unit really good. Tested
while it was out of the tractor and got the
switch to work.
Big M
Post A Followup
: Re: Re: Farmall H won't start
