Posted by pete 23 on October 09, 2010 at 19:40:50 from (184.12.32.90):
In Reply to: 1944 H oil pressure posted by ericy on October 09, 2010 at 16:19:04:
I would prefer a good 75 psi gauge over a 60 but you can try what you have to establish is you have low pressure or just bad gauge. Oil pump covers are pretty heavy on the H, not like the pot metal ones on smaller tractors like C so the cover doesn't usually give much trouble. But, the shafts in those pumps wear out bad and then you loose hot oil pressure at low speeds. Sticky, gummed up relief valves and weak or broken spring other problems. Wrong relief valve got circumvented into a lot of these H and M's due to parts mix up many, many years ago resultling in about 45 psi tops.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
