Re: Farmall A PTO seal
Posted by bkpigs on October 10, 2010 at 07:27:58 from (12.69.254.226):
In Reply to: Re: Farmall A PTO seal posted by CNKS on October 10, 2010 at 07:23:54:
I was thinking maybe the other one was for the belt pulley also but, I told them mine has the belt pulley delete cover. Oh well. I will keep the other one as a spare if the B loses the seal for the pulley, if that is what it is for.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
