Re: Farmall A PTO seal
Posted by gene bender on October 10, 2010 at 08:25:20 from (67.55.227.196):
In Reply to: Farmall A PTO seal posted by bkpigs on October 10, 2010 at 05:56:16:
If they are the same then he figured you will put two in as they are thinner than original and sometimes two can be used.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
