Farmall Tractors Discussion Board
Re: 806d hydraulics trouble
Posted by Kenneth Updike on January 02, 1999 at 05:42:08:
In Reply to: 806d hydraulics trouble posted by Norm Demers on January 01, 1999 at 21:06:24:
First off change the oil...its junk!!! Then replace the HYD filter, its probably plugged. If these two things don't fix the problem, replace the pilot relief valve with a valve from a 1086. This will solve the problem most likely.
Post a Followup
: Re: Re: 806d hydraulics trouble
