Re: Re: Belly Pump on F-20
Posted by Regularman on June 20, 2000 at 09:46:01 from (147.160.180.17):
In Reply to: Re: Belly Pump on F-20 posted by The Red on June 20, 2000 at 08:35:49:
I'll try to answer a few questions. If you have a two port cylinder. Plug the unneeded port with a VENTED cap (available at any hydralic place). The valve that operate the pump is a three postion valve; raise, hold, and drop. Be sure you have the valve in the drop postion the wieght of the implement should cause it to drop.
Post A Followup
: Re: Re: Re: Belly Pump on F-20
