Re: The 886 needed some time apart
Posted by pete 23 on October 10, 2010 at 20:05:09 from (184.12.32.90):
In Reply to: The 886 needed some time apart posted by mh on October 10, 2010 at 17:25:32:
For sure have flywheel resurfaced, I can't tell about ring gear from picture. How is starter drive gear as that would be an indication of need for ring gear replacement as well as drive gear. I would put a new rear oil seal in also, and check for wear of pto drive gear splines and new seals on them also.
