Re: Another MD split question
Posted by Janicholson on October 11, 2010 at 06:38:06 from (199.17.6.223):
In Reply to: Another MD split question posted by BruceS. on October 11, 2010 at 05:55:58:
If there are 4 bolts on each fram rail (8 total) (I think there are) Then the two bolts above the starter at the top of the bousing remain to be removed. There are also dowel pins htat force alignment of the casting to the rear engine support plate, and the support plate to the engine block (internal under flywheel and will show up after split. Jim
